Remote desktop remote FX, Win 11
ponka
Post by ponka »
Hello
I have a spacemouse. When I work at home I use remote desktop.
I previously had win 10 on my home computer but now upgraded to win 11. Work cumputer has win 10 enterprise.
The problem is that now I can't use my spacemouse, it was fine before on win 10.
I have followed the below guide and made settings in Group policy. Did it before on win 10 and it worked fine.
But now in win 11 the correct settings in remote desktop do not appear. When i go to:
Edit remote desktop → Local resources → More → Other supported RemoteFX USB Device don't appear.
How can I fix this?
https://learn.microsoft.com/en-us/azure ... al-desktop
luping
Re: Remote desktop remote FX, Win 11
Post by luping »
Use VirtualHere to connect the SpaceMouse via usb port forward, free for one device or one usb port forward:
https://virtualhere.com/home
luping
Post by luping »
Make sure that both computers have 3DxWare installed.
ponka
Post by ponka »
Hi
Both have 3DxWare.
I work at a large company and the software needs to be "safe" to be allowed to be installed. So best would be that it's a Microsoft software or a well known company. Do you know any? And I don't think I can install https://virtualhere.com/ if it needs to be installed at my company computer.
luping
Post by luping »
ponka wrote: ↑Thu Nov 07, 2024 11:53 pm Hi
Both have 3DxWare.
Do you have another SSD(Solid State Drive) in your home computer that can install Windows 10 OS? Install the Windows 10 OS on a second SSD. Otherwise, do a clean install of Windows 10 OS in your current hard drive, your home computer's OS activation information is stored at Microsoft's data centre, once Windows 10 is reinstalled and connected to Internet, the activation should be automatic.
cacciatorino
Post by cacciatorino »
luping wrote: ↑Thu Nov 07, 2024 5:35 pm Use VirtualHere to connect the SpaceMouse via usb port forward, free for one device or one usb port forward:
I guess that this software makes usable on the local machine a piece of hardware that is phisically connected to the remote machine. Here is the reverse.
luping
Post by luping »
cacciatorino wrote: ↑Fri Jan 31, 2025 3:54 am
You're right.
sempre-doug
Post by sempre-doug »
VirtualHere USB Server/Client works for me over a Tailscale VPN connection to the remote RDP machine.
I'm using Win11 Pro on both the ends of the RDP session to forward my local SpaceMouse Wireless (connected via USB cable) to the RDP SolidWorks session.
Here are the steps I used:
1. Install and run the VirtualHere USB server on the local PC, default settings.
2. Install and run the VirtualHere USB client on the remote PC.
3. VirtualHere on the remote system did not automatically find the USB server, so I added it manually. Right-click on USB Servers in the client window and choose "Specify a USB Server", then add the VPN IP address of the RDP local machine running the VirtualHere USB server with port :7575.
4. Once connected, the client will display a list of the available remote USB devices, double-click SpaceMouse Wireless to use the device.
I'm not sure if it matters, but I do have all the RemoteFX registry changes originally required for the previous Win10 method.
