3D spacemouse randomly stops working
Whyneversimple
Post by Whyneversimple »
Macbook pro, Apple M2 max, sonoma.
Issue: when starting a sketch the 3D spacemouse stops working. I then have to close down fusion, stop and restart the 3D connexion program and restart Fusion for it to start working again.
This sometimes happens 10 times in an hour and other times i can work for days without any issues, you can see when it happens if i open a sketch and it has a small lag/glitch then the spacemouse stops working.
Using the latest driver from 3D Connexion.
This has happened with 2 different spacemouses, imo ruling out a hardware problem, not sure if the issue lays within Fusion of within 3D connexion.
Any solution available?
skmiec
Re: 3D spacemouse randomly stops working
Post by skmiec »
Hi Whyneversimple
Can you please tell if you have any specific setting in your 3Dconnexion prefPane?
Do you use 3DConnexion CadMouse or not?
