Switching to Camera mode in Houdini
Petey
Post by Petey »
Hi!
I was just setting a spacemouse up for Houdini in macos and I was wondering, Is there a way to easily set it to "camera" mode rather than "Object" mode? I couldn't figure it out, do I have to change each axis manually?
Pete
FridJane
Re: Switching to Camera mode in Houdini
Post by FridJane »
In Houdini, you can switch your SpaceMouse to "Camera" mode by adjusting the settings in the 3Dconnexion driver or within Houdini's preferences under Edit > Preferences > 3D Mouse. Look for an option to switch between Object Mode and Camera Mode.
barkerxavierr
Post by barkerxavierr »
FridJane wrote: Wed Mar 26, 2025 8:30 am In Houdini, you can switch your SpaceMouse to "Camera" mode by adjusting the settings in the 3Dconnexion driver or within Houdini's preferences under Edit > Preferences > 3D Mouse. Look for an option to switch between Object Mode and Camera Mode.
hi i am a newbie and i did exactly as you instructed and it worked fine. thank you so much!
