Chitubox - help, all motion reversed - how to fix !???
n0f8r
Post by n0f8r »
By default all movement is reversed in Chitubox and the Spacepilot - and the config file C:\Users\kevin\AppData\Roaming\3Dconnexion\3DxWare\Cfg\CHITUBOX-KMJ.xml does in fact have reversed set to true for all Axes, but setting them to false does nothing and reversing the axes in the 3Dconnexion control panel advanced settings does nothing either.
Can anyone help??
thanks,
Kevin.
n0f8r
Re: Chitubox - help, all motion reversed - how to fix !???
Post by n0f8r »
Fixed - settings get cached - even if you make changes in 3Dconnexion driver control panel and restart chitubox, the old settings still apply. Google gemini put me on to the fact the driver was holding on to old settings
I would call that a bug. Anyway - I restarted the PC because stopping the driver didn't stop the mouse operating in chitubox. After restart the new settings file with the axes reversed values set to false is applied.
