he issue is that the dedicated Middle Button on the CadMouse Pro Wireless ignores the command assigned to it in 3DxWare when using Archicad 29.
For example:
In the Archicad 29 profile in 3DxWare, I assign Middle Button → Application Command → Fit in Window.
I close the 3Dconnexion Settings window.
In Archicad 29, while in Floor Plan, I press the dedicated Middle Button.
Instead of executing Fit in Window, Archicad opens the 3D Window.
The behavior is also contextual:
With no element selected, the Middle Button opens the general 3D view.
With an element selected, the Middle Button opens the 3D view showing that selected element.
Most importantly, the Middle Button still produces this same behavior even when it is set to Disabled in 3DxWare.
Other CadMouse buttons correctly execute their assigned Archicad commands. Therefore, the problem appears to be specific to the dedicated Middle Button and its interaction with Archicad 29.
Could you please advise whether this is a known issue with Archicad 29 and 3DxWare 10.8.13 on macOS, or whether there is another setting that overrides the Middle Button mapping?
System:
Mac Studio
Archicad 29
3DxWare 10.8.13 (3908)
3DxMacCore 1.4.4.623
CadMouse Pro Wireless firmware 1.23
CadMouse Pro Wireless Archicad issues
Re: CadMouse Pro Wireless Archicad issues
Please assign keyboard shortcut commands.
https://community.graphisoft.com/t5/Get ... a-p/303831
https://community.graphisoft.com/t5/Get ... a-p/672706
