Need help on the number pad pro to work again
henri
Post by henri »
I accidentally pulled the USB cable while it was updating, now it will not work anymore. I can hear the beep when I connect and disconnect a USB cable . It also shows up as Scout Keypad Boot on Bluetooth & devices. Anyone had a suggestion how to fix this issue?
Thank you!
AmroSalih
Re: Need help on the number pad pro to work again
Post by AmroSalih »
