Maya 2009 + SpaceNavigator
Anyone got the SN working in maya 2009? Just curious, everything installs ok with me, and i get no error messages, but it doesnt work.
Re: Maya 2009 + SpaceNavigator
Hi skabear,
Please refer to this topic. Support for Maya 2009 is not yet available.Anyone got the SN working in maya 2009?
Why SN PE doesn't work with Maya 2009
Today, I have just purchased my first SN PE. It works incredibly well with Google Earth. However, it seems that Maya 2009 doesn't recognize my 3D mouse, although I have installed 3DxMacWare (PE) v.1.5.6. Do I have to set anything in Maya up before I can use it?
Oliverj777
Maya 2009 - SN
My SpaceNavigator does not seem to work with Maya either. Does anyone know anything that might be able to help me?
SN works but ...
Hi to all you guys, so i managed to install the SN for notebook driver into my MBP ... but when Maya is launched happens something strange.
The scene camera begins to zoom out by itself, so i can' get in control of the scene and the object gets far away atuomatically.
So please tell me if i've done something wrong during the installation.
Greetings
Greetings
This article shows how to find the System Preferences (sorry for not making this clear). There will be a section named "Other" - there you will find the 3Dconnexion Preference Panel.
Robert Stadie
I'm also having the same problem in maya 2009.
On starting maya I get this printed out in the Script Editor
also tried
MagellanStartup;
The prefs about says it has found 1 device and the driver version number is 1.5.6, firmware 4.04
I found "3DxMaya.bundle" in /Users/Shared/Autodesk/maya
Tried to manually load this plugin but maya the same error again...
Hope its a quick fix
Cheers
Richard
// Warning: Move Scene //
// Warning: Rotate around center of Camera! //
// Warning: Fly mode on! //
// Warning: Rotation Scale 1 //
// Warning: Translation Scale 1 //
// Error: Plug-in, "3DxMaya" was compiled against too old a version of the Maya API and is thus incompatible with the current Maya version. (3DxMaya) //
// Warning: No Magellan device found. Start 3DxWare and then restart Maya
file -f -new;
// untitled // also tried
MagellanStartup;
// Error: Plug-in, "3DxMaya.bundle", was not found on MAYA_PLUG_IN_PATH. // I found "3DxMaya.bundle" in /Users/Shared/Autodesk/maya
// Error: Plug-in, "3DxMaya" was compiled against too old a version of the Maya API and is thus incompatible with the current Maya version. (3DxMaya) // Cheers
Richard
Hi Yellowhey,
It appears some 3Dconnexion Maya files were not placed in their correct location. 3DxMaya.bundle should reside in /Users/Shared/Autodesk/maya/2009/plug-ins.
Please check to see if a 3DxMaya.bundle exists in that directory. If there is one, backup then delete the 3DxMaya.bundle file in /Users/Shared/Autodesk/maya
I'll email you the bundle file in case you don't have it
