alfredix wrote:The good news is: The beta version does not make it worse
I hope you are not angry about my sarcastic post.mbonk wrote:alfredix wrote:The good news is: The beta version does not make it worseTrue: The fixes for Pro/E x64 didn't make 3.1.1. They will be in 3.1.2, so no need to worry quite yet.
The short and sweet answer: Yes.Brieldo wrote:an update on my situation. The only message I'm getting now is:
"Startup of application '3DxProENGINEER' failed"
In the lower message/info area, the message reads:
"Pro/TOOLKIT application '3DxProEngineer' was built to run with a newer version of Pro/Engineer."
"Pro/TOOLKIT version 0.0, Pro/ENGINEER version 27.0"
So, would this be the issue that will be resolved in the newer release?
We have completed the qualification of our product for Pro/ENGINEER. The fix for Wildfire 3 x64 (add-in not loading) has been verified.Brieldo wrote:Where we at on the fixes for this issue?
I'm in the midst of trying out 3.1.3. I'll say that even with 4GB RAM, the use of the SpacePilot induces a lot of lag following lots of movement of the part or assembly. Also, the 3dConnexion menu freezes probably 50% of the time when accessing it from within Pro/E. Finally, when using the SpacePilot and then reverting back to the mouse to do a movement, there is considerable lag, sometimes to the point of requiring a Cntl-Alt-Del and closing the xtop.exe process, and restarting pro/E. I will post more as I try various features out.ngomes wrote:Hi Brieldo,
The second beta of release 3.1, version 3.1.3, can be downloaded from the software page. Please make sure you uinstall version 3.1.1 first before updating.
We appreciate if you could post here your test results.
