Camera Mode toggles itself off
penorjr
Post by penorjr »
:lol:
When using SN in SketchUp 6, the Camera Mode will toggle itself off, especially after changing Scenes. This has become very annoying!
Earl
agoenczi
User
User
SketchUp 6 - Camera Mode toggles itself off
Post by agoenczi »
Hi penorjr
Please specify how we could reproduce this issue.
Thank you.
penorjr
Camera Mode Toggle
Post by penorjr »
Saturday, it was toggling off all day long. Now, for some strange reason, I can't get it to do it.
I'll watch and report if it does it again.
Earl :?
CCRDude
Post by CCRDude »
Actually, I've experienced that constantly over the past days with 3.1.1 beta, and now with 3.1.3 beta ... for me (large model, not sure if this plays a role since I didn't notice it early in my work).
I experienced it whenever I saved (Ctrl+S always), so very easy to reproduce. The camera mode will switch, though the button on the 3DConnexion-toolbar in Sketchup 6 will appear to still be down.
penorjr
Did it again
Post by penorjr »
Hi CCRDUDE...
Glad to here I am not the only one experiencing this problem. It did toggle off again this afternoon, unfortunately, I was not paying attention to the previous steps...but, in my case the button does not stay on. However, that said, I can remember a few times when that was not the case, as you have experienced. In those cases, I actually had to toggle it thru a couple of cycles to get the Camera mode to return functionality.
Earl :lol:
Hi CCRDude,
CCRDude wrote: I experienced it whenever I saved (Ctrl+S always), so very easy to reproduce. The camera mode will switch, though the button on the 3DConnexion-toolbar in Sketchup 6 will appear to still be down.
This has been reproduced. The problem is being tracked internally as issue 4339. Thanks for the information. The toolbar button remains pressed down until you touch the device cap, then the button will became depressed.
An update. Issue 4339 has been resolved. The fix will be available in release 3.3 (soon to be made available for download).
alz
Post by alz »
I just installed 3.5.6 to fix the Camera Mode resetting with every new scene/open/start, but it still doesn't remember the setting.
Is there some system config file I can manually set this? (ie. user01.scg)
