I didn't get this to work on either platform.
With XP 64 bit, the driver installation went flawlessly but when I started the .exe it stated "SpaceNavigator not found". No changing values for the device, no changing in the joystick setup,... nothing.
On Windows 7 I got a little further (I know it's still a beta, but I thought I'd give it a try). After disabling driver signature the driver installation went ok and when I started the .exe, I could see changes in the joystick setup, enter the space tool, see the changing values, enter a configuration and hit the apply button. But that's when things got messy. The configuration didn't get saved and when I reenterd the configuration window all settings were lost. The applied settings were nothing I had set up but a jumbled mix with every axe doing something different and once I hit one of the two hardware buttons everything went totally haywire. The task bar icon stated "SpaceNavigator not found" and nothing worked any more.
Sorry, but no success with 64bit here as well. But on the plus side: no BSOD.
