same problem as before with a spaceball 4k serial
ghostofrcon
Post by ghostofrcon »
Hey guys i had a problem with the USB spaceball a couple days ago where i had installed the software, but the driver wouldn't start and the space ball wouldn't come on.
Well I got that one to work by holding the 1 and 2 buttons and disconnecting it and holding the 2 button while reconnecting.
I have the same problem with a spaceball 4k today and the afore mentioned method was to no avail. Any help you provide would be great:)
-Dave
The terms hero and live are quite often mutually exclusive.
Fred
Post by Fred »
1,2 button fix will not work on a Serial device, try the below.
Specify com port.
1. Go to Start...Programs...3dxonnexion...3dxware...(right click) on "Start Driver" go to "properties".
2. Edit the "Target" line.
Old Line:
"C:\Program Files\3Dconnexion\3DxWare\3DxSrv.exe" -searchWarnDlg
New line:
"C:\Program Files\3Dconnexion\3DxWare\3DxSrv.exe" -com 1
3. save configuration
4. Start driver.
P.S depending on your com ports you may have to change the -com 1 to a -com 2 etc.
ghostofrcon
didn't work
to identify the com port i opened up hyperterm and selected com2 (the device beeped upon clicking ok) then clicked buttons on the space ball. Characters appeared on the screen.
then i edited the shortcut and tried to start the driver and nothing happened. I have power cycled the machine to no avail
-Dave
ghostofrcon
here is the debug
3Dxwal"e
14:1:5.335:
3Dxwal"e
dl"ivel"
stal"tup:
5/13/2009 14:1:5
14:1:5.335:
3DxWal"e
Dl"iver Version 6.6.4 : October 22, 2008
14:1:5.335:
-quiet --disabled '.
14:1:5.335:
-shutdown --disabled
14:1:5.335:
-protocol none given. All protocols enabled.
14:1:5.335:
-com --
using com port 2.
14:1:5.335:
-dev --
Attempting to autodetect device type.
14:1:5.335:
-eps disabled sending each event.
14:1:5.335:
-log enabled
14:1:5.335:
-loglevel ffffffff
14:1:5.335:
-logFile C:\Documents and settings\telkins\Application
Data\3Dconnexion\3Dxware\3Dxware.log
14:1:5.335:
-searchwarnDlg not enabled
14:1:5.335:
-showGUI not enabled
14:1:5.335:
-hideGUI not enabled
14:1:5.335:
UdCtl: Attempting to find (10;1033)
'English' locale in EN_US
14:1:5.335:
UdCtl: Found resource Dll in c:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3Dxware\EN_US\3dxsl"v.dll
14:1:5.335:
udCtl: initialization successful.
14:1:5.335:
udctl: Attempting to open Any Device (-1) on USB.
14:1:5.335:
udctl: Attempting to load device Dll: c:\pl"ogl"am
Files\3Dconnexion\3Dconnexion 3DxSoftware\3Dxware\udDev\HIDDev.dll
14:1:5.350:
UdDev: Attempting to open 3DX-Suppol"ted
HID device on USB
14:1:5.350:
udCtl: Unable to open Any Device (-1) on USB.
Page 1
-Dave
Re: here is the debug
Hi ghostofrcon,
This driver support USB devices.
For a SB4K serial, you will need to download and install a different build. You can find the software for your 3D mouse in the Driver Downloads web page.
