Driver problem in 64 bit
I have problem with install the 2,8,2 driver , and problem with correct work in the system windows 7 64 bit somebody know when 3dconnection will support this windows ?
also I try to install driver on windows xp 64 bit , the problem is the same I can't install driver on this OS,
On the main website 3dconnection there isn't driver special for this windows.
I have a another questions will this driver work under the windows vista 64 bit ultimate ?
no sign
3Dconnexion software for 3D mice with a serial port connector (RS-232) is available only on:
Windows 2000 SP4
Windows XP RTM and all service packs (32-bit only)
Windows XP Professional
Here is the link to the knowledgebase regarding discontinued devices:
http://www.3dconnexion.eu/support/kb/?V ... EntryID=40
Serial driver support ended back in December of 2006.
Windows 2000 SP4
Driver Support
OK - SpaceNavigator PE USB Driver Support...........
So when is a driver going to be available for XP64 or Vista or Windows 7? I can't image that there hasn't been one written already.
Vista 64, SolidWorks 2009 64 bit
I am trying to use my Space Navigator under Vista 64, in SolidWorks 2009; I have reloaded the drivers (and rebooted, too, Fred) and the 3DXWare just refuses to load.
I am also running a Wacom tablet and a bluetooth mouse.
Any idea why the hardware is AWOL?
thanks.
thanks.
Patrick Girvin
Make sure you have the Device plugged directly into a USB port on the pc or laptop.
Donot use a hub.
Try unplugging the device.
Hold down the 1,2 button
while holding them down
plug in the device
wait 15 seconds and release
Now try to open the 3dxware control panel
If it open the device is recognized.
next open Solidworks
Donot use a hub.
plug in the device
Re: Vista 64, SolidWorks 2009 64 bit
Hi Patrick,
please give this a try: unplug the Wacom tablet and de-activate the driver software for the tablet. if possible reboot. Then see if the os finds the device.
Can you see it in the device manager (see here)?
