The undo feature in Pro-E is not working when the 3dconnexion software is installed. If I disable the protk.dat file, then undo works, however the buttons I have assigned do not.
We are running Wildfire 4.0 M092.
Has anyone found a workaround for this that doesn't involve disabling the use of the buttons.
Thanks for any help.
Undo not working in Pro-Engineer
Re: Undo not working in Pro-Engineer
Hi Sparxhawk,
the issue you describe is a known issue and unfortunately can only be fixed by PTC. If you contact PTC and open a ticket there maybe that would help to push this issue. Internally we track this issue with number #4836.
