Shortcut is mapped to the keyboard it happens when I do some operations in maya. For example when I press the enter key in the channel box (using the keyboard) 3dconnexion driver keeps madly pressing the enter key until i kill it.
I also experience slowdowns when I use smooth proxy and move the mouse across the screen while moving with the space pilot. If I don't move the mouse across the screen while navigating I get like 250 fps in poly proxy but when I just move the mouse across the screen and navigate I get serious viewport lag less than 1/3 fps.
Driver version is 1.4.0, Space Pilot firmware version V4.04
I checked the cpu when this enter key issue happens there is no significant change in cpu usage.
Hope this info gets you a better idea what the problem is
