Spacenavigator not working in sketchup
fredS
Post by fredS »
Spacenavigator is not working properly for me in sketchup version 7. What it’s doing when I try to rotate a 3d model is it jumps in large steps. In this configuration the thing is next to useless.
It performs the way I think it should in Google earth.
I reinstalled the driver and it didn't change anything.
What's wrong?
What to do?
skell
Post by skell »
reply so i can make a new topic.
also on topic, i have a space explorer, it works in sketchup6 but not seven
Bryan
SpaceNavigator and SketchUp 7
Post by Bryan »
Dear fredS,
What release version of 3DxSoftware do you find listed in the 3Dconnexion Control Panel using the About Item under the Help Menu?
Sincerely,
Bryan
fredS
Post by fredS »
release version 3.7.18
driver version 6.7.13
firmware version 3.18
New discovery -- When I turn (VIEW - EDGE STYLE > DISPLAY EDGES) OFF, then rotation and all the other functions are smooth. When I set that back to ON then its back to being jumpy allthough now it's not as bad. It's actually useable.
Re: Spacenavigator not working in sketchup 7
Hi skell,
did you install Sketchup 7 after you installed the 3DxSoftware? If yes, you should run the "Update Wizard".
