SpaceNavigator and 3dStudio xp64
mpillman67
Post by mpillman67 »
I'm testing this device to see if it works better then the built in "steering wheel" or viewcube. When I try to move the model using the space ball it has a three second delay and THEN it starts to rotate while the steering wheel is immediate.
I've played with the sensativity and other settings for the past month and I can't quite get the performance I can get using the mouse. Anyting I am missing or maybe a different spaceball will give me better results?
Mike
Bryan
AutoDesk 3DS MAX and SpaceNavigator on XP-64
Post by Bryan »
Dear mpillman67,
What version of AutoDesk 3DS MAX?
What release version of 3DxSoftware?
(3Dconnexion Control Panel, Help, About)
Do you have Security Software checking your ports that may be slowing you down?
Sincerely,
Bryan
