LED control via HID
sschaefer
LED control via HID
Post by sschaefer »
I am able to get the rotation and translation values from the SpaceNavigator via HID and to rezero it with the 7-0 packet, but i am wondering which HID-packet is turning on the LED?
Thanks in advance !!
2 byte packet 4, 0 turns off the LEDs. 4, 1 turns them on.
sschaefer
Post by sschaefer »
Thanks for your quick answer... it works. :)
Tiwen
Post by Tiwen »
i changed in the HIDRezero example
			pFeatureBuf[0] = RPTID_FEAT_REZERO_DEVICE,
			pFeatureBuf[1] = 0x00;
to
			pFeatureBuf[0] = 0x04,
to switch of the LED, but i get the error
SendRezeroCommand: error from HidD_SetFeature (0x17)
(wrong CRC)
and i am wondering what i have done wrong. Any suggestions?
That looks reasonable. Do you have a SpaceNavigator? Have you successfully opened it?
Tiwen
Post by Tiwen »
Yes, i have a SpaceNavigator, and i successfully created a library to query the hid device.
I can rezero the device with this source without problem an i have only changed this singe byte in the code.
I also tried to send 4,0 and 4,1 with DeviceIoControl (IOCTL_HID_SET_FEATURE), same error ...
and same error on other computers (Windows XP and Windows 7 64Bit).
The Spacenavigator has no problems with other Software/Drivers.
For example the driver from RBC9 is able to control the LED.
Any idea?
That's the packet the 3DxWare driver uses to set the LEDs.
The error seems to indicate that the error is somewhere else. The packet is probably fine.
Tiwen
Post by Tiwen »
Thanks for the fast response jwick, but i have no clue where there could be an error.
Does anybody have a simple working example that controls the LED with HidD_SetFeature or DeviceIoControl?
(a modified HIDRezero would be perfect)
Thanks in advance
sschaefer
Post by sschaefer »
Hi Tiwen, I had the same problem. HidD_SetFeature didn't work for me either (except for the callibration). I used WriteFile instead:
HidDevice *pDev = waitListItems[index];
//turn LED on
pDev->buf[0] = 0x04;
pDev->buf[1] = 0x01;
WriteFile(pDev->handle, pDev->buf, pDev->capabilities.OutputReportByteLength, &nwrite, FALSE);
//turn LED off
pDev->buf[1] = 0x00;
Tiwen
Post by Tiwen »
Great, that works :D
romani
Re: LED control via HID
Post by romani »
I have a SpaceNavigator, and i successfully created a library to query the hid device.
I can re zero the device with this source without problem an i have only changed this singe byte in the code.
romani wrote:I have a SpaceNavigator, and i successfully created a library to query the hid device.
It's not a feature report. Just write it to the device.
sayala
Post by sayala »
I am planning to use SiSetLED function to turn off/on LED on space navigator. with the following defines
#define LED_ON 0x00010001
#define LED_OFF 0x00010000
How do i find out the current LED state on space navigator? Is it the return value of SiSetLED function?
sayala wrote:I am planning to use SiSetLED function to turn off/on LED on space navigator. with the following defines
The return value of SiSetLEDs is just success or failure. We don't provide a way to get the state of the device LEDs. You can look into the user's configuration to see if they have turned them on/off. It's best not to mess with their preferences though.
sayala
Post by sayala »
what should be the input values for SiSetLED function? The following values not working
SiSetLEDs(m_pscs->devHdl, LED_ON);
