Hi everyone
I've installed the space navigator driver and Maya 2011 drivers on Red Hat Enterprise 6.
No errors reported on installation though xcube will not start (missing libXm.3.so shared libraries, some kind of old open motif 3 subset)
The Maya plugin loads but I can't navigate the scene. The cursor is being moved all around but not the objects or the camera as in my Mac version.
Any suggestions?
El
Maya 2011 plugin moving the cursor not the 3d scene !
el.mustafa
Re: Maya 2011 plugin moving the cursor not the 3d scene !
Hi El,
can you see the driver running? It might be that the HID system driver grabs the 3D mouse, but as soon as you start the 3DxWare daemon (/etc/3DxWare/daemon/3dxsrv) the 3D mouse should not move anymore the cursor.
el.mustafa
Hello El,
could you please post the complete output of the command
- ls -l /etc/3DxWare/daemon
el.mustafa
Ok. Looks good so far.
Do you still have the entry in the /etc/inittab?
- 3d:2345:respawn:/etc/3DxWare/daemon/3dxsrv -d usb </dev>/dev/null 2>&1
- 3d:2345:respawn:/etc/3DxWare/daemon/3dxsrv -d usb -debug -E -multiLogs </dev>/dev/null 2>&1
el.mustafa
Hi uludwig,
Gratefull for following this up.
Adding the options you recommended to the inittab did not generate any log files.
The cursor movement has stopped but the device will only start moving the camera when I start it manually. Apart from that it is working perfectly. To be honest if it wasn't going to be an obvious step that I missed in the installation or something similar that has a quick fix to it now I'm thinking Iought not to mind starting the device manually. As long as it works !
Take care
El
Take care
El
