I just now updated my Driver and discovered that the Camera Mode no longer switches to Center of Rotation on a Save Command. THANK YOU...THANK YOU!! That was such an annoyance.
I have had my "Space Pilot" for a few weeks now. It takes some "getting use to," ...but once I got comfortable with it, I LOVE IT!
It seemed at first that problem was fixed, and I think it might be... partially. But, I am still having issues with needing to reset the Mode to Camera. Once in awhile...it still wants to switch itself back to "Center of Rotation."
Is there a way to set it so it defaults to Camera...instead of Center of Rotation?
If you check the extension version, you will see if it is the same as before (v. 2.0.0). The issue you reported back in early February remains to be fixed but you're not forgotten. Just bear with us for a while.
