Hello all,
3DxSoftware64_v3-14-0_r1145.exe was installed on Windows 7 64bit (German). Unfortunately I cannot launch the Collage application.
Here is the information from the event viewer:
Name der fehlerhaften Anwendung: 3DxCollage.exe, Version: 1.3.0.642, Zeitstempel: 0x4d4c2cd9
Name des fehlerhaften Moduls: 3DxCollage.exe, Version: 1.3.0.642, Zeitstempel: 0x4d4c2cd9
Ausnahmecode: 0x40000015
Fehleroffset: 0x00030b2f
ID des fehlerhaften Prozesses: 0xef0
Startzeit der fehlerhaften Anwendung: 0x01cc5cfafaa590a9
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\3Dconnexion\3Dconnexion 3DxSoftware\3DxCollage\3DxCollage.exe
Pfad des fehlerhaften Moduls: C:\Program Files (x86)\3Dconnexion\3Dconnexion 3DxSoftware\3DxCollage\3DxCollage.exe
Berichtskennung: 3998bead-c8ee-11e0-8348-000c29b857b0
I've tried to install different VC+ redist packages (2008 x86/x64 and 2005) without any success. Also .Net 4.0 is installed on this PC.
Can somebody help me with this issue?
Problem with 3Dconnexion Collage 1.3.0
Hi ukrserg,
in the meantime we released an update for 3DxSoftware 3.14. Could you please uninstall the version you have now and install the very latest?
Please let me know if the problem exist with that version, too.
Hello ukrserg,
go to our download page (www.3Dconnexion.com -> Service -> Download Drivers) and select your device and operating system and press "Search". At the bottom of the page you will get a possibility to download the installation package for your driver.
The same problem with v3-14-1_r1161:
Protokollname: Application
Quelle: Application Error
Datum: 22.08.2011 13:15:59
Ereignis-ID: 1000
Aufgabenkategorie:(100)
Ebene: Fehler
Schlüsselwörter:Klassisch
Benutzer: Nicht zutreffend
Computer: testenv
Beschreibung:
ID des fehlerhaften Prozesses: 0xc70
Startzeit der fehlerhaften Anwendung: 0x01cc60bcc680b586
Berichtskennung: 1cb53364-ccb0-11e0-8fca-000c29b857b0Hi ukrserg,
the 3DxCollage needs "Direct3D Acceleration". To check for Direct3D acceleration support, go to Start menu, select Run and
launch the "dxdiag" tool. On the DirectX Diagnostic Tool, go to the "Display" and check the "Direct3D Acceleration" field in the "DirectX Features" control group.
If the setting is not enabled you might have to update the graphic card driver ...
