u should not have to change to value in the inf ..means u dont have to correct one.majeancad wrote:RBC9:
I complete the update driver process and encounter two problems:
1. Even though I have all the devices (RBC9 SpaceTraveler MouJoyKey v2, HID Keyboard Device and HID-compliant mouse) as describe after updating the driver process, the pointer / cursor doesn't move.
2. When I launch the RBC9*.exe file the window is cut off at the bottom at the Deadzone slider bar level. I can see the tip of the Apply, Calibrate and Cancel buttons with no word. This is probably due to my laptop 1920x1200 native screen resolution.
Please advise.
plz , try to uninstall all RBC9 Stuff , unplug
check if the inf file is removed in windows\inf dir.
and the rbc9-Spacenavigator.sys is also removed in windows\system32\drivers
and reboot b4 re-install with new doanload.
for the screen size , are u sure ? the form has a this size 951x739 ... should not be too large.
