I am trying to install the SpaceNavigator on a RHEL 5.5 workstation.
If I start the driver as root, I can run xcube as a normal user. The driver is spawned normally true init, however, then users can't use the driver, they get an error:
user@wumc0345 ~ > xcube
No driver is running. Exit ...
as root you can see I have the latest driver version:
wumc0345 ~ # /etc/3DxWare/daemon/3dxsrv -v
3DxWareUNIX = V1.5.3, ID 6913
wumc0345 ~ # cat /tmp/3DxWare.log
3DxWareUNIX V1.5.3 ID 6913 log file
Process ID: 4893
Time: 2011-08-25 15:40:16
Machineinfo 1: Systemname=Linux, Nodename=wumc0345, Release=2.6.18-194.17.4.el5
Machineinfo 2: Version=#1 SMP Mon Oct 25 15:50:53 EDT 2010, Machine=x86_64
Runlevel-Info: run-level 5 May 12 09:07 last=S
[2011-08-25 15:40:16] uddev.c, 711: UdDevInit() 0x9f38010
[2011-08-25 15:40:17] 3dxsrv.c,806: displayname = $DISPLAY set to :0
[2011-08-25 15:40:17] 3dxsrv.c,811: putenv() was successful
[2011-08-25 15:40:17] 3dxsrv.c,813: displayname is now :0
[2011-08-25 15:40:18] auth.c :: authGetUser(), FOUND: user home = "/home/seltsam"
[2011-08-25 15:40:18] 3dxsrv.c :: startupInittab(), authGetUser(), user=seltsam
[2011-08-25 15:40:18] UdDev: Opening USB device on USB port /proc/bus/usb/001/030
[2011-08-25 15:40:18] UdDev: Opening SpaceNavigator on USB port /proc/bus/usb/001/030
[2011-08-25 15:40:18] snav_usb.c :: UdDevRezero(): Rezeroing the device
[2011-08-25 15:40:18] snav_usb.c :: UdDevSetDeadband(): Setting deadband to 26
[2011-08-25 15:40:18] 3dxsrv.c,831: UdDevOpen() was successful [SpaceNavigator]
in the logs of the machine I see:
/var/log/messages:
Aug 25 15:29:34 wumc0345 kernel: usb 1-2.1.4: usbfs: process 3196 (3dxsrv) did not claim interface 0 before use
Aug 25 15:29:34 wumc0345 gconfd (seltsam-31387): Received signal 15, shutting down cleanly
Aug 25 15:29:34 wumc0345 gconfd (seltsam-31387): Exiting
Aug 25 15:29:51 wumc0345 init: Re-reading inittab
Aug 25 15:30:15 wumc0345 init: Re-reading inittab
Aug 25 15:30:16 wumc0345 kernel: usb 1-2.1.4: usbfs: process 3263 (3dxsrv) did not claim interface 0 before use
Any ideas why I can't make the driver spawn so that normal users can user it?
SpaceNavigator under RHEL 5.6
Re: SpaceNavigator under RHEL 5.6
Hi oz,
does the driver start from the /etc/inittab if you do a
- xhost +
- 3d:2345:respawn:/etc/3DxWare/daemon/3dxsrv -d usb -debug -E </dev>/dev/null 2>&1
Hi Uta,UtaSH wrote:Hi oz,
- xhost +
yes the driver starts. In fact, as I wrote the drive is always present. Here is an example:
wumc0345 ~ # pgrep 3dxsrv
24671
wumc0345 ~ # kill 24671
24797
wumc0345 ~ # #process respawned ...
wumc0345 ~ # xhost +
access control disabled, clients can connect from any host
24797
wumc0345 ~ # kill 24797
24813
wumc0345 ~ # xcube
I already did in my first post...UtaSH wrote:Hi oz,
Can you provide a log file from a driver start from the /etc/inittab? Please change the entry in the /etc/inittab to:
Hi oz,
so if you have the entry in the /etc/inittab active the driver window opens?
Did you check if the process number of the 3dxsrv process is always the same (if you don't kill it
Do you get several logfiles if you change the entry in the /etc/inittab to:
- 3d:2345:respawn:/etc/3DxWare/daemon/3dxsrv -d usb -debug -E -multiLogs </dev>/dev/null 2>&1
what is the "driver window" ?UtaSH wrote:Hi oz,
the only way I test it now is xcube, other applications obviously fail to work with the mouse.
when do user logs out, the process is killed, and restarted, so the pid is not the same after logout, relogin ...Did you check if the process number of the 3dxsrv process is always the same (if you don't kill it)?
I am only getting this:Do you get several logfiles if you change the entry in the /etc/inittab to:
wumc0345 ~ # ls /tmp/*log
/tmp/3DxWare.log /tmp/ks-script-7WlDcr.log
There should be a window "3DxWare 1.5.3" that is the control panel for the driver. Our driver is not a kernel driver, but running in user space. Do you have that window?oz wrote: what is the "driver window" ?
What other applications did you try? The xcube only starts if it finds the window of the driver.oz wrote: the only way I test it now is xcube, other applications obviously fail to work with the mouse.
Yes, when a user logs out the driver is killed and then re-started from the init process. I was just interested if it keeps the same process number when you do not kill it and do not log out.oz wrote: when do user logs out, the process is killed, and restarted, so the pid is not the same after logout, relogin ...
Please launch aoz wrote: I am only getting this:Code: Select all
wumc0345 ~ # ls /tmp/*log /tmp/3DxWare.log /tmp/ks-script-7WlDcr.log
- init q
