Spacepilot pro computer slowdown
kraaijkamp
i tried to find the answer on here but couldn`t find it
i`ve recently reinstalled my laptop for school
Acer aspire 7520G with 7 64 bit
and before i could use my spacepilot pro just fine but now when i start it my comp goes bonkers and almost slows down to a crawl
this happens when i use my spacepilot and only then i have to restart my comp because unplugging it does nothing
does anybody know what i could do
kraaijkamp
Hello kraaijkamp -
Can you check whether you have a single instance of the 3Dconnexion driver loading?
You will see it listed in your Startup folder [Start|All programs|Startup] as 'Start 3DxWare'.
When you check Task Manager, go to the Processes tab and look at 3dxsrv.exe.
Check the memory usage for the 3dxsrv.exe process.As you move the SpacePilot cap you should see the memory increase then decrease again as you stop moving the cap.
Also , you mentioned needing to reboot. It sounds like unplugging the SpacePilot is not stopping the driver and that is unusual. You can normally stop the driver with the Stop Driver shortcut or by right-clicking the 3Dconnexion system tray icon and choosing Exit.[Start|All programs|3Dconnexion|Driver|Start-Stop Driver]
The driver should stop once the SpacePilot is unplugged.If it does not, you could end the process.
You should be able to stop the driver then check how that affects the CPU load.
kraaijkamp
kraaijkamp
kraaijkamp
kraaijkamp
