I have developed a solution to connect a spacenavigator to a AVR mikrocontroller for a CCTV project to control cameras.
It worked very well with older versions of spacenavigators ( > 1-2 year old )
Now, something has change in firmware ( or hardware ) of the actual spacenavigators.
My solution is not working any longer with these newer ones.
I started to analyse. Is the newer version using now USB-Fullspeed ???
If this is so, is it possible to config the spacenavigator to low-speed on default ?
If not, can I downgrade the firmware of the spacenavigator ?
Greetings from germany
Thommy
Connecting Spacenavigator to Mikrocontroller
