Hi all
I have been using Space Pilot pro in Maya on the 2011/2012...emigrated to 2013 now and for some reason I can't map actual orthographic views. All it does is give a pseudo orthographic in the perspective window.
I am positive I mapped the buttons before and it worked perfectly but I can't remember how, or was it just different before...
Has anything changed that anyone knows of?
Its really frustrating having to spacebar move to another panel when I have always just pushed a button to jump between the orthographic and perspective vies.
Thanks in advance.
Tim
Maya 2013 Orthographic view change?
Re: Maya 2013 Orthographic view change?
Because the ViewSet in 3dconnexion plugin (MagellanViewSet 1(2, 3...)) sensitive to camera settings. If the camera perspective, the ViewSet will also be perspective. If the camera is orthographic, then ViewSet will also be orthographic.
I can offer two solutions to the problem. Use this code to toggle between orthographic and perspective views:
Or instead of 3dconnexion plugin ViewSets, use internal Maya ViewSet bookmarks, which orthographic by default.:
$state = `camera -q -orthographic persp`;
camera -e -orthographic (!$state) persp; Code: Select all
viewSet -b(-bo, -f, -ls, -p, -rs, -t);Re: Maya 2013 Orthographic view change?
Thanks. I figured it out. Turned out that it doesn't work like the Wacom settings panel. You have to do a 'save as' so my settings weren't saving. Dumb-ass.
Thanks for your posts though.
Tim
Tim
owen.global
How to i use that code to fix the problem, also is there a way to run a mel from a button on pilot pro?
