When I stop using my 3d mouse, I get successive SI_ZERO_EVENTs in a row. While this isn't a massive problem, I wasn't expecting them and so just wanted to check this was normal, or whether I had an issue that might be causing other problems.
I'm using a Space Traveller, which I realise isn't a supported device any more, but it does seem to work with the current SDK and old drivers that do support it.
Successive SI_ZERO_EVENTs.
Re: Successive SI_ZERO_EVENTs.
That's an issue with the 3D mouse driver, not your program. It is normally innocuous as programs will simply ignore all subsequent zero-data packets.
The new driver stack (3DxWare 10) will have that fixed.
Thanks for the reply, reassuring to know that's all it is. Just a shame my Space Traveller isn't supported with the later drivers. I am hoping I can get a newer device at some point, as I'm using one on loan at the moment.
