Reverse zoom
applestalk
Reverse zoom
Post by applestalk »
I can't seem to reverse the zoom using Mac OS X 10.6.8
I've tested it in SecondLife and if I pull backwards the avatar walks forwards and vice-versa. Clicking the "Reversed" check-box in the Preference Pane does nothing!
Has anyone else experience with SL or Firestorm?
applestalk
Re: Reverse zoom
Finally managed to find the answer to this one.
1) DON'T add a custom application, leave it on "Any Application"
2) then in Advanced, Reverse the Zoom Axes
My mistake was thinking that adding the application actually did something.
Re: Reverse zoom
Hi applestalk,
I do not think you were mistaken. Adding a profile for an application should work.
Have you considered using 3DxWare 10 Beta for OS X? It is reaching the end of the test program and should be fine for day-to-day use. You can get the latest build from the 3Dconnexion Labs page here.
