Spacepilot Solidworks 2014
averell
Post by averell »
Hello
The driver for my spacepilot PRO works for solidworks 2014 but my spacepilot does not work. When will a driver for spacepilot be avaliable ?
Fred
Re: Spacepilot Solidworks 2014
Post by Fred »
Sorry the SpacePilot is a Legacy device.
Driver update support ended 31-Mar-2013 .
http://www.3dconnexion.com/faq/39
But you can try the driver for the SpaceMouse Pro (3DxSoftware 3.17.7). It should recognize your SpacePilot and installs the plugin for SolidWorks 2014.
averell
Post by averell »
Hi
It didnt work with that plugin, has anyone succeded?
Post by Barbara »
Hello averell -
When the 3DControl add-in is installed but there is no navigation in SolidWorks, the problem is usually permissions. While the SpacePilot is beyond extended support, this is something that is the same for all of the current devices and SolidWorks versions. It is a requirement in Vista, Win 7 and Win 8 that the permissions for an add-in match the permissions for the application.
When SolidWorks is installed with elevated permissions [Run as administrator] the 3Dconnexion software requires the same permissions.
Changing the permissions to match the SolidWorks permissions is described here.
wayforwarddesigns
Post by wayforwarddesigns »
Hi
And thanks this work round worked!! Solidworks 2014 on Window 8 Laptop, thanks again I thought I was going to end up with a very expensive paper weight. :D
