I usually spend a long amount of time trying to find technical solutions by searching high and low for people who have had similar problems. However this particular issue seems to be eluding me at every turn and I haven't been able to find any help
I've had the SpacePilot Pro for about 3 months now and its a very useful piece of equipment. Except for one incredibly large caveat that's been gaining momentum causing me to finally post on this forum.
To briefly explain: When trying to use the SpacePilot Pro's nub sensor in 3Ds Max while at the same time moving the cursor anywhere around the viewport, it causes a very strange stuttering that is a little hard to explain.
Essentially what happens is the viewport say rotates with the 3D mouse but attempting to move the mouse at the same time causes the viewport to ... switch or flicker all over the place. Makes me very dizzy. Navigating the view port without touching the mouse at all is fine. However any movement whatsoever of the mouse while navigating with the Spacepilot causes the viewport to go bonkers.
I have actually narrowed it down a little in that the viewport does not glitch out when the tool being used is "Select Object". If the mouse is equipped with say: "Rotate", "Move" or "Scale" the above behavior is experienced.
Also, the problem is not experienced at all on a fresh new scene with very few objects on the screen. Even on the busier scenes the problem only becomes apparent after about 10 minutes while everything worked perfectly prior.
At first I almost thought it was because of a lack of system memory, but that doesn't appear to be the case. It is only occurring in very specific instances and the task manager does not reflect any kind of memory overload.
The only thing I could think of is a potential conflict with some kind of view port setting, but since the problem is never apparent early in a scene I don't think that is the case.
If it helps at all I will make a small video clip to help explain what the problems looks like.
My system specification are as follows (If this helps):
3D Connexion SpacePilot Pro
Autodesk 3Ds Max 2014 Version 16.0 SP3
Intel i7 3770K CPU
Asus P8-Z77-Pro Motherboard.
Asus GTX 780 Direct CU II
16 GB 1600Mhz Patriot Extreme Masters RAM
OCZ 750W Modular Power Supply
OCZ Vertex 4 256 GB Solid State Drive
Corsair H80 CPU Liquid Cooler
Corsair Graphite Series 600T Case
Windows 7 Home Premium
Thank you for reading my question and I would appreciate any help on this issue
