I installed the latest software V10 for the Space Pilot Pro with Inventor 2014. When I rotate the model and then release the rotation it acts like I am still rotating and the model keeps spinning. I tried to recalibrate the device with no luck. Anyone else have this problem. Any help would be appreciated.
Jamie
Space Pilot Pro, Inventor 2014, Software 10
Re: Space Pilot Pro, Inventor 2014, Software 10
Is the device plugged directly into the pc USB port or through a Hub or Monitor?
Plug it directly into a USB port on the pc.
Try a miss calibrate.
If the calibrate function is either not correcting a problem with drifting or is correcting it only briefly ,there is another step you can try. As a slight variation on the calibration process, you can intentionally miss-calibrate by holding the device cap away from center for several seconds and pressing the Calibrate button while the cap is off-center. Then, let the cap return to its center position and press Calibrate again. By causing the distance away from center to become larger before re-zeroing it can sometimes be more easily corrected.
