Loss of functionality in SW
pleshrl
Post by pleshrl »
Typical Monday. I have no issues using my space Navigator in AutoCAD, but when I start up solidworks, only the buttons work (both of them). I have no pan, zoom, rotate or anything. How does that happed? I have restarted 2x, pulled the plug on the navigator, restored all the settings to default but still nothing.
It worked when I left Friday. All the demo's and training work.
Any suggestions?
Re: Loss of functionality in SW
Post by Barbara »
Hello pleshrl -
Loss of navigation in SolidWorks can be caused by permissions that have changed. As long as SolidWorks was closed during the driver re-install, the 3DxSolidWorks add-in is installed.
Microsoft requires permissions for an add-in to match the application permissions. Check SolidWorks is using elevated permissions. If it is , the 'Run as Administrator' option on the compatibility will be checked.[sldworks.exe |Properties|Compatibility]
If you find that SolidWorks is using the 'Run as Administrator' option, close SolidWorks , run the 3Dconnexion installer using the right-click 'Run as Administrator' option and choose 'Repair'.
pleshrl
Post by pleshrl »
Barbara,
Thansk for the itdea. SolidWorks is NOT running with elevated permissions, the "run as administrator" box is not checked.
Any other suggestions?
pleshrl
Post by pleshrl »
I called tech support. They had me shut down the driver then delete a reg key (see picture entire folder {7B9E5423-5CD.....}) and finally do a repair on the program in the control panel. Worked like a charm.
3d conx.gif (29.44 KiB) Viewed 11116 times
Fred
Post by Fred »
That was me you spoke with on the Phone .
Glad I could help.
Barb sits next to me and was just asking about this post for any other suggestions to try.
She was just getting ready to send you a private message with the answer.
pleshrl
Post by pleshrl »
Darnit all, happened again today. I cannot remeber how to shut the driver off. Can you post that? Thanks.
There is a shortcut under Start -> All Programs -> 3Dconnexion -> Driver -> Stop Driver (and Start Driver).
zeplin
Post by zeplin »
I was having the same problem in CAD. Thanks for sharing the solution, saved me a ton of time I would have spent trying to figure it out. :)
