I've updated my spacepilot driver to 3.3.2 (the last version), and after this, a strange behavior occurs in 3dsmax view: when I move or rotate view, the name switch from "3dxvStudio perspective" to "perspective" (or left, top, etc. depending from the view) continuously, and heavly slow down the operation (but using the standard 3dsmax view manipulations this doesn't happens). Sometime, when I launch 3dsmax, all works fine, but after a few seconds the problem reappears. Before the update everything's ok. I've tried to reinstall, reload drivers, but nothing change. Someone have some idea, or know where i can find old drivers?
thanks
Spacepilot 3dsmax view issue with last drivers
andreas_ld
Same for me
Just installed spaceexplorer with Max9 64bit. Unacceptably slow response from SpaceExplorer, mouse is smoooooooooth.
this has been discussed here viewtopic.php?t=917
