RCB9 Win7 64Bit Help !!!
techfree
Post by techfree »
Hi all,
I tred to install the rcb9 driver on win7 64bit but he doesnt wont install.
Can some help and show step by step how to get it work on win7 64bit ?
I ahve tried with the DSEO driver enforcement but no luck :(
Thank you very much for your help.
techfree
Re: RCB9 Win7 64Bit Help !!! [SOLVED]
Post by techfree »
Hi guys,
I solved my problem !
It work very fine.
I have done the following on Windows 7 x64:
-Download Driver Signature Enforcer Overrider and unzip to a directory
-Download RBC9 driver for x64 and unzip to a directory
-Start the DSEO in Admin mode
-Choose "Enable Test Mode"
-Choose "Next"
-Choose "Exit"
-Choose "Next"
-Restart your computer
You should now see Test Mode Enabled at the bottom right of your desktop, indicating that drivers with a test signature can be used.
-Open Control Panel > Device Manager > Human Interface Devices >
-Browse through USB Input Devices > Properties
-In tab Details > Hardware > Find USB Input Device with ID USB\VID_046D&PID_C626
-Right click that USB Input Device, choose "Update Driver Software"
-Choose "Browse my computer for Driver Software"
-Choose "Let me pick from a list of Device Drivers on my computer"
-Choose "Have Disk"
-Browse to the RBC9 Driver directory
-Choose the "RBC9 MouJoyKey v2" driver for your device model (in my case "RBC9 SpaceNavigator64 MouJoyKey v2") from the list and apply.
Your driver should now be installed, but still needs to be signed with a test certificate.
First turn off UAC in win7
follow tutorial here
When done you must restart the computer again to take effect.
Now
-Choose "Sign a System File"
-Give in the path and driver name in your systems driver directory (C:\Windows\system32\drivers\RBC9-SN.sys by default)
-Choose "Next"
-Choose "Exit"
Test mode should be enabled now, and if you look in your Driver Manager, you should now see an USB Device named "RBC9 SpaceNavigator64 MouJoyKey v2" without a yellow warning triangle.
-Start the "RBC9-SpaceNav.exe" from the RBC9 driver directory
You should now see numbers at the axis when you move the SpaceNavigator, and be able to bind the axis to joystick, mouse or keypresses.
Voila !!
