Wait or Delay function for 3dxware 10 custom macro
The old software had a wait function that i had to use to keep keystrokes from piling up when using custom macros in AutoCAD 2015. Is there a way to add this into the .XML File?
Re: Wait or Delay function for 3dxware 10 custom macro
Hi AButler,
If you do not mind getting yourself in to editing driver profiles, you can try the following:
To get the key ID numbers, you can look at how user-created macros are saved. When you use the driver panel, the changes are saved in %APPDATA%\3Dconnexion\3DxWare\Cfg (normally this expands to C:\Users\<user name>\AppData\Roaming\3Dconnexion\3DxWare\Cfg).
- Stop the driver and AutoCAD.
- Open the AutoCAD.xml file ("Cfg" directory of the driver installation folder) in a text editor.
- Add a new button action of type "MotionMacro" immediately after the <ButtonActions> element.
- Save the file.
- Start the driver and then start AutoCAD.
- Open the "3Dconnexion Properties" panel and then the "Buttons" panel.
- Pick the button that you want and look for the new action in the "3Dconnexion" category.
- Select (click) the action to assign it.
- Return to AutoCAD and press the button that you assigned the new action.
<ButtonAction Type="MotionMacro">
<ID>MotionMacro_PressASD</ID>
<Name>Motion Macro Test</Name>
<Event>KeyPress(04); KeyRelease(04); Pause(1000); KeyPress(16); KeyRelease(16); Pause(1000); KeyPress(07); KeyRelease(07); Pause(1000); </Event>
<Increment>0</Increment>
<Count>0</Count>
<Sleep>0</Sleep>
</ButtonAction>
This is the spot in the code i need to add a pause. For this macro i am entering a length to a line then trying to finish the line command then restart the line command by pressing enter again. Problem is the "<KeyPress>28</KeyPress>" is the enter key and if i have 3 in a row it just keeps creating the line without ending the command. So i end up with 2 ".125" lines stacked instead of creating the .125 line then "enter" to accept it followed by "enter" to end the command followed by an "enter" to restart the line command. If i type those keys myself it works but when using the same sequence in the macro it seems to process to fast for AutoCAD. Thanks in advance for any help. I just couldn't see how your code would fit into my .xml file.
Aaron
Aaron
<MacroEntry>
<ID>Sink Centerline</ID>
<Sequence>
<KeyPress>37</KeyPress>
<KeyRelease>37</KeyRelease>
<KeyPress>1E</KeyPress>
<KeyRelease>1E</KeyRelease>
<KeyPress>1F</KeyPress>
<KeyRelease>1F</KeyRelease>
<KeyPress>22</KeyPress>
<KeyRelease>22</KeyRelease>
<KeyRelease>28</KeyRelease>
</Sequence>
</MacroEntry>Re: Wait or Delay function for 3dxware 10 custom macro
Hi AButler,
You will need to add the new "ButtonAction" (of type "MotionMacro") to the AutoCAD.xml file in the driver installation directory.
The macro that you posted has the necessary key codes that you will need to use.
My AutoCAD.xml File doesn't have a <ButtonAction> area. I have <ButtonBank>... I attached my entire code for you to review. This is a new frontier for me. I can usually figure stuff like this out but I guess I'm just not seeing or understanding it correctly. I tried adding the code you supplied in a couple areas but i couldn't get the new button to display.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<AppCfg Default="false" xmlns="" CfgFormatVersion="1.1" ThisFileVersion="1.21">
<AppInfo>
<Name>STR_AUTOCAD</Name>
<ExecutableName>acad.exe</ExecutableName>
<ApplicationIcon>AutoCAD.ico</ApplicationIcon>
<Transport>S80</Transport>
</AppInfo>
<CfgProperties>
<InheritsFrom>STR_AUTOCAD</InheritsFrom>
<Access />
</CfgProperties>
<Settings>
<OverallScale>5.00</OverallScale>
</Settings>
<Devices>
<Device>
<VendorID>0</VendorID>
<ProductID>0</ProductID>
<Axis>
<Enabled>false</Enabled>
<Input>
<Min>-512</Min>
<Max>511</Max>
<Deadband>0</Deadband>
</Input>
<Output>
<NameID>STR_TILT</NameID>
<Min>-512.0000</Min>
<Max>511.0000</Max>
<Scale>1.0000</Scale>
<Reversed>false</Reversed>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<NameID>STR_ROLL</NameID>
<Max>511.0000</Max>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<NameID>STR_SPIN</NameID>
<Max>511.0000</Max>
</Output>
</Axis>
</Device>
<Device>
<Name>SpaceExplorer</Name>
<VendorID>46d</VendorID>
<ProductID>c627</ProductID>
<ButtonBank Default="true">
<ID>Default</ID>
<Button>
<Input>
<ActionID>HIDButton_13</ActionID>
</Input>
<Output>
<ActionID>Window Right</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_14</ActionID>
</Input>
<Output>
<ActionID>Window Left</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_3</ActionID>
</Input>
<Output>
<ActionID>F8</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_5</ActionID>
</Input>
<Output>
<ActionID>Chamfer</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_4</ActionID>
</Input>
<Output>
<ActionID>Delete</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_6</ActionID>
</Input>
<Output>
<ActionID>Fillet</ActionID>
</Output>
</Button>
<Button>
<Input>
</Input>
<Output>
<ActionID>Macro_AutoCAD_Line</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_15</ActionID>
</Input>
<Output>
<ActionID>Explode</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_9</ActionID>
</Input>
<Output>
<ActionID>Align</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_2</ActionID>
</Input>
<Output>
<ActionID>Sink Centerline</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_10</ActionID>
</Input>
<Output>
<ActionID>Driver_Toggle_3DxNumPad</ActionID>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>
<MacroTable>
<MacroEntry>
<ID>Window Right</ID>
<KeyStroke>
<Modifiers>
<Modifier>Control</Modifier>
</Modifiers>
<Key>2B</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>Window Left</ID>
<KeyStroke>
<Modifiers>
<Modifier>Shift</Modifier>
</Modifiers>
<Key>2B</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>F8</ID>
<KeyStroke>
<Key>41</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>Delete</ID>
<KeyStroke>
<Key>4C</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>Chamfer</ID>
<Sequence>
<KeyPress>6</KeyPress>
<KeyRelease>6</KeyRelease>
<KeyPress>B</KeyPress>
<KeyRelease>B</KeyRelease>
<KeyPress>4</KeyPress>
<KeyRelease>4</KeyRelease>
</Sequence>
</MacroEntry>
<MacroEntry>
<ID>Fillet</ID>
<Sequence>
<KeyPress>9</KeyPress>
<KeyRelease>9</KeyRelease>
</Sequence>
</MacroEntry>
<MacroEntry>
<ID>Explode</ID>
<Sequence>
<KeyPress>8</KeyPress>
<KeyRelease>8</KeyRelease>
<KeyPress>1B</KeyPress>
<KeyRelease>1B</KeyRelease>
<KeyPress>13</KeyPress>
<KeyRelease>13</KeyRelease>
<KeyPress>F</KeyPress>
<KeyRelease>F</KeyRelease>
<KeyPress>12</KeyPress>
<KeyRelease>12</KeyRelease>
<KeyPress>7</KeyPress>
<KeyRelease>7</KeyRelease>
</Sequence>
</MacroEntry>
<MacroEntry>
<ID>Align</ID>
<Sequence>
</Sequence>
</MacroEntry>
<MacroEntry>
<Sequence>
</Sequence>
</MacroEntry>
</MacroTable>
</AppCfg>Re: Wait or Delay function for 3dxware 10 custom macro
nevermind i was using the file in appdata not the one in the install area. I should work on my reading.
I've been there and done that.AButler wrote:nevermind i was using the file in appdata not the one in the install area.
Let us know how you get on.
Works perfectly. Can i adjust the delay from the (1000)? Thanks again I have been missing that button for about 6 months now. Can i just copy that file in the Installation area to the others people in my dept. I would like to configure all the keys that we use so they would just have to pick the location on the space ball and not worry about programming anything. Also is the a legend that shows what the "key code" is for each key or does it differ based on computer and keyboard?
ngomes wrote:I've been there and done that.AButler wrote:nevermind i was using the file in appdata not the one in the install area.
Yes. The number is in milliseconds. I think you can use anything larger than zero.AButler wrote:Can i adjust the delay from the (1000)
That's one approach. There's another method to distribute "default" profile files: copy them in "%ProgramData%\3Dconnexion\3DxWare\Cfg". Please make sure you test this carefully as I do not recall what takes precedence (if the file in %ProgramFiles%... or in %ProgramData%...).AButler wrote:Can i just copy that file in the Installation area to the others people in my dept.
That key code is invariant but keyboards are very confusing devices: it is the operating that converts the key code (not exactly the same but equivalent to a "scan code") into an actual character. That conversion is dependant on the "locale" that the target program is set to. If you have AutoCAD.exe running with a German locale, you will get a different key sequence than what the same application would get if run in -- say -- an English locale.AButler wrote:Also is the a legend that shows what the "key code" is for each key or does it differ based on computer and keyboard?
In case it helps someone, this also works with the CADmouse in this form
so all the keypresses were entered via the properties box, then the delays - via <Pause>xxx</Pause> added on their own lines to the xml. Thanks for your help finding this.
<MacroTable>
<MacroEntry>
<ID>Excel find xxx</ID>
<Sequence>
<KeyPress>E0</KeyPress>
<KeyRelease>E0</KeyRelease>
<Pause>250</Pause>
<KeyPress>29</KeyPress>
<KeyRelease>29</KeyRelease>
<Pause>250</Pause>
<KeyPress>4C</KeyPress>
<KeyRelease>4C</KeyRelease>
</Sequence>
</MacroEntry>
</MacroTable>
I have the Spacemouse Enterprise and I have tried to adjust the autocad.xml file according to the steps you have provided and then my spacemouse stops working and just shows that there is no application selected. I'm not sure if this is what I need but it looks to be. I want to create a custom macro that lets me type in a few letters then enter then delay for a half to 1 second then another letter and so on. So it looks like this is what I need. The location of the xml file I adjusted is C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg which is the only place I can find the autocad.xml aside from the AppData location. Any help you can give would be greatly appreciated.
Here is what it looks like. Am I missing something or did I do it wrong?neodd70 wrote:I have the Spacemouse Enterprise and I have tried to adjust the autocad.xml file according to the steps you have provided and then my spacemouse stops working and just shows that there is no application selected. I'm not sure if this is what I need but it looks to be. I want to create a custom macro that lets me type in a few letters then enter then delay for a half to 1 second then another letter and so on. So it looks like this is what I need. The location of the xml file I adjusted is C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg which is the only place I can find the autocad.xml aside from the AppData location. Any help you can give would be greatly appreciated.
<ButtonActions>
</ButtonAction>
These are the only ButtonActions that will be displayed to the user.
<!-- Macros -->
<ButtonAction Type="Macro">
<ID>Macro_Open</ID>
<Name>STR_OPEN</Name>
</ButtonAction>
<ID>Macro_Save</ID>
<Name>STR_SAVE</Name>
</ButtonAction>
<ID>Macro_SaveAs</ID>
<Name>STR_SAVEAS</Name>
</ButtonAction>
