I just got the 3Dconnexion SpaceNavigator, downloaded the latest drivers and started to have a play around.
Its working really well in Google earth and naviswork. But in Sketchup 2015 I'm having a problem with the speed. The walk is really fast and very hard to control (pan, move forward/backwards, up and down) where as lookaround is very slow (tilt, rotate).
I have it in camera mode, with the setting changed as much as I can (speed of the pan etc to the slowest and the speed of the tilt, rotate at the fastest).
I think there is something very wrong as I really dont think it should come this way. If anyone can help that would be great.
Thankyou
Also, running windows 8.1
Sketchup, twist/tilt slow, slide/pan fast?
Re: Sketchup, twist/tilt slow, slide/pan fast?
Hi bachamp,
I cannot really reproduce what you are seeing. Which version of Sketchup 2015 do you have? (I have 15.1.106) And which version of the driver is installed?
Sketchup 15.3.331
3DxWare 10.2.3
3DxWinCore 17.2.3.11261
SpaceNavigator firmware v. 4.35
3DxWare 10.2.3
I'm not the only one having the issue:
http://forums.sketchup.com/t/3dconnexio ... 15/3390/38
