Can't get setup to change for different programs
rr299
Post by rr299 »
I've installed the most recent driver for a spacenavigator. I recently had this working but had to reformat my PC.
I am unable to get it to work properly.
First issue... If I try to run the trainer it doesn't work. The teapot never moves it just moves the mouse cursor.
Second issue... when I run properties the set up just gets stuck on desktop mode. I am actually trying to change the buttons for ProE / Creo. With Creo open and active, the properties panel remains in desktop mode.
I've uninstalled/reinstalled etc etc but no joy.
Any help appreciated, thanks!
Re: Can't get setup to change for different programs
Do you have 3DxWare 10.2.3 installed?
Try FAQ #1100.
rr299
Post by rr299 »
Yes 10.2.3
rr299
Post by rr299 »
I didn't see the link before but that worked. THANKS!
JPA
Post by JPA »
Had a similar problem.
Was working in Solidworks
Playing with the radial menus by choosing different options.
Trying to find something I would like to use.
Looked in 2D mouse area hoping to find a toggle to turn of rotation when working in sketches or what not.
Sometimes I just want to move around zooming and panning but not rotating.
WELL
It jammed the 3Dmouse into Desktop mode.
Did exactly what the moderator suggested in FAQ #1100 (including making a system restore point).
WORKED!
back up and running
still looking for a FAST way of toggling rotation on/off
