C# / C Sharp Example
Re: C# / C Sharp Example
Can somebody send me the link to the C# example please. Needed urgently. Thanks
Hi JIyare,
As mentioned in a couple of post before, sample source code is no longer available from the FTP server. Please contact 3Dconnexion's API Support team and they will assist with your request.JIyare wrote:Can somebody send me the link to the C# example please. Needed urgently. Thanks
Sorry for the delay with this but I now know the answer, it was my fault, I have too many versions of TDx.TDxInput on my PC. I deleted them all and reinstalled the 3D Connection drivers and now my program does not crash however I still have to finish it.Zoony wrote:I can build csMonitor to an exe with Visual Studio 2010 and run it on my Win7 64bit system no problem and my SpaceMouse Wirelss is read correctly, BUT . . .
I need it to run as a DLL for a plugin with my host application. I created a new project with a new form that has only one textbox and this loads okay from my application menu.
The problem is I get this error;
System.InvalidCastException: Unable to cast object of type 'TDxInput.Device' to type 'TDx.TDxInput.DeviceClass'.
Can someone please send me example C# code to use the latest SDK? Thanks!
Hi mspivey,
If you can, please contact 3Dconnexion's API Support team as the FTP server with the "unofficial" samples has been retired. The API Support team should be able to assist you.Can someone please send me example C# code to use the latest SDK? Thanks!
Please, send me the link to the C# example.
I would be very helpful.
Thanks.
Thanks.
Can I have the link to the c# examples too please
Thank you
Thank you
Hi, I would also need the C# example urgently. Would be glad, if somebody could mail it or give me links to download. Support has not answered yet on request.
Thanks in advance!
Thanks in advance!
Can someone send me a link to the C# code example.
Couldn't find a working link anywhere on the web...
Hi aetz,
Please contact 3Dconnexion's API Support team and they will assist with your request.Hi,Can someone send me a link to the C# code example.
I'd like to get the example also... Would you please send me the link via PM? Thank you very much! ![Smile :)](./images/smilies/icon_smile.gif)
Hi mao871109li,
As mentioned before, please contact 3Dconnexion's API Support team and they will assist with your request. We're not distributing source code outside the scope of API Support.I'd like to get the example also... Would you please send me the link via PM? Thank you very much!
I send Email to them, but no one cares about me.ngomes wrote:Hi mao871109li,As mentioned before, please contact 3Dconnexion's API Support team and they will assist with your request. We're not distributing source code outside the scope of API Support.I'd like to get the example also... Would you please send me the link via PM? Thank you very much!
They must respond. Could you please send me a PM with the e-mail address and date of the e-mail you sent to API Support?I send Email to them, but no one cares about me.
I receive the reply,thank youngomes wrote:They must respond. Could you please send me a PM with the e-mail address and date of the e-mail you sent to API Support?I send Email to them, but no one cares about me.
