I am thinking of purchasing SpacePilot PRO. I borrowed older SpacePilot just to get my hands on the joystick, and I have faced some questions thinking about newer device. I will appreciate if you share your experience.
1. You can swap all buttons with older SpacePIlot: I assigned Ctrl to Alt key, Shift to Ctrl key- this way it is more like regular keyboard and is easier to work with. I want to make sure this will also be possible with SpacePilot PRO. Could somebody please confirm ?
2. I use a lot of doube key shortcuts, for example Ctrl + Key1 etc. Works perfectly with SpacePilot. I read that PRO version has the feature of long-press the button (you can bind second command to the key if you hold it for 1 sec or more). Could you please confirm that PRO version works with double key shortcuts - Ctrl+ something, Alt+ something etc?
3. I do not have the possibility to try SpacePilot PRO - so I can not test how it feels, but I am slightly concerned about how ergonomic are the keys in the picture below. I mean - are they easily accessible without too much hand movement? How do you feel about them?
