64-bit 2.6.xx driver available?
winny
Post by winny »
My unsupported but fully functional setup SpaceMouse Plus serial, Windows XP 64-bit and SolidWorks required me to lift an old driver around 2.6.xx for 64-bit XP and a SolidWorks plugin from a later version (2.8.xx on the legacy section works fine), but since then I had to reinstall and I can't find the old driver CD anymore. Heck, even finding that one in the first place was a hassle but I diged though the pile of driver CDs at work and they had used 3Dconnexion products since the SpaceBall-era so no problem there.
Does anyone still have it?
winny
Re: 64-bit 2.6.xx driver available?
Post by winny »
No one has any old driver CD laying around?
Hello winny,
the driver 2.8.2 from the archive driver download site should work for the SpaceMouse Plus serial.
winny
Post by winny »
UtaSH wrote:the driver 2.8.2 from the archive driver download site should work for the SpaceMouse Plus serial.
Hi!
Not for 64-bit. The installation program does run and all the plugins are installed but the driver isn't. If I extract the driver installer from the package,, then you can actually see the error message produced that it failed to install.
I'm thinking about hijacking an 32-bit installation, inject the 64-bit driver and force run it that way, but an old 2.6.xx CD would be far easier.
Select the CadMan as device on the archive page. There is a 64bit driver for it. This one should recognize the SpaceMouse Plus serial, too.
