I have an older Space Pilot, on a windows 7, 64bit machine, running driver version 3.16.3. Sometimes when I quit using NX, the SpacePilot screen will continue to show the NX options, and is essentially dead. Driver won't stop or start, or at least gives no indication. I've tried the SpacePilot reboot, button 1 and 2, and plug in and hold for 15, no luck. a computer restart seems to be the only fix.
Thoughts?
SpacePilot driver stops working
-Dave
Siemens NX2206 with Windchill
SpaceMouse Pro and CADmouse
Re: SpacePilot driver stops working
Hi Dave,
It could be that the driver crashed. You should have a message in the log file. Turn on logging (systray) and email your log file to me the next time it happens. Being 3.16.3, there is nothing I can do about it, but I might be able to tell you what went wrong. Can you upgrade to 3DxWare 10?
Jim
Jim
I could upgrade to 10, but when I went to the drivers download page for that device, it gave me 3.16.3, so I wasn't sure if it would work.jwick wrote:Hi Dave,
Jim
-Dave
The SP still works with the current release. It just has a greyed out picture and a "discontinued" label.
We don't test the discontinued devices. Things might break as time goes on. Last I checked, the SP still worked fine. But it is getting pretty old.
Tell the download page you have a SpaceMouse Enterprise.
Sweet, it seems to be working!
-Dave
@jwick FYI: it looks like the latest driver somewhat breaks the old Space Pilot. My shift, control, etc. keys no longer work. Going to check my archives, and see if I have the older version yet.jwick wrote:The SP still works with the current release. It just has a greyed out picture and a "discontinued" label.
-Dave
3DxWare 10.4.10?
It should work. I just tested the modifier keys for a few minutes (Explorer/Jet).
What application? Maybe we messed up a cfg file for a specific application.
Make sure the installation was completely successful. If you don't have the KMJ emulator in the DeviceManager, the modifiers won't work.
