Big Problems with Windows 10
Trashcanmike
Post by Trashcanmike »
Just upgraded to Windows 10 from 8.1.
Now the reverse ticks in the advance settings are not recognised, making my device next to useless. Tried it on 2 different apps and two different driver versions.
Has anyone else seen this behaviour? Does anyone have a fix?
Lodged a support ticket but it's only been a few hours and I am desperate. I really don't want to go back to W8.1 but if I don't have a solution in 24 hours I will have to. Clients waiting!
Cheers
Mike
Re: Big Problems with Windows 10
If changing settings in the GUI have no effect, chances are the device driver (3DxHID.sys) is not installed for your device. Check the Device Manager->Human Interface Devices. Your device should be in there with the name "3Dconnexion whateveritis".
Trashcanmike
Thanks for the reply.
I am using a Space Mouse Enterprise.
The only HID reference is for a "3Dconnexion Euclid"
Is this correct or is this the problem?. If so what next?
Cheers,
Mike
Trashcanmike
Some more info:
I have a SMPW as well. I plugged that in and it does remember the tick boxes so it navigated OK BUT.....On both devices NONE of my macros work. Even if I delete them and reprogram them they don't work. This is in Petrel.
