CADMouse
abr
CADMouse
Post by abr »
Windows 7 Pro
3DxWare 10.4.5
I have just purchased the cadmouse and the shortcuts i assigned work in Autocad 2017 Mechanical but not in Autocad 2017 (vanilla).
Any suggestions?
Re: CADMouse
Hello abr,
please check which configuration file is used when AutoCAD 2017 is the active window and which one is used if AutoCAD Mechanical 2017 is used. You do that by moving the mouse cursor over the 3Dconnexion icon in the system tray; a little window shows up that tells you the name of the configuration file (extension .XML).
