Latest driver 10.4.5 and NX
after instal latest driver 10.4.5 in windows 10 x64 pro, Siemens NX10 start slowly (15s - before cca 2s).
In NX11 same situation.
Re: Latest driver 10.4.5 and NX
Hello gajdos,
have you had another version of our driver installed before? Did you see this problem there as well?
Is NX installed locally or on a server?
What is the exact version of NX?
What 3Dconnexion device are you using?
I have Spacenavigator and use NX 10.0.3 MP07 (instaled locally).
Version of driver 10.4.3 working properly. 10.4.4 - same problem as 10.4.5
Hello , I have the same problem as partner.
I installed the 10.4.5 version 3dWare and NX11 takes a lot to boot .
Do we know why ?
Do we know why ?
Try the latest one - 10.4.6 - and let us know if this fixes the issue.
With driver 10.4.6 - same situation.
Continuing the problem with new drivers.
Hi, grateful for the work that went into the new tool we just got - Wireless Spacemouse, X4! Works beautifully, thanks.
We too have the same issue; slow start-up on NX11 running the 10.4.6 drivers. Works perfectly fine without the driver loaded (or with the win7 system env var deleted).
We can cope with the bug (4 users) but curious to know if this bug will be looked at for a near driver release. Whether GTAC to take it seriously (unlikely) or 3DConnexion to offer a workaround?
NX11
Win7-64
Wireless Spacemouse (w/ 10.4.6)
NX11
Win7-64
Hello again
I can confirm that 10.4.7 fixed the slow loading issue in NX11. Works perfectly now!
Much appreciated, 3Dconnexion. We'll certainly buy again (and again).... hopefully soon when you guys release the wireless CAD Mouse
All the best of luck in everything you guys do there
M
M
Hello,Cadcom wrote: I can confirm that 10.4.7 fixed the slow loading issue in NX11. Works perfectly now!
thanks for the feedback! I should have posted earlier here in the forum that with 3DxWare 10.4.7 the issue should be fixed.
Now it works perfectly.
