Hi I have problem with export and import object in 3ds MAX. After that my SpaceNavigator does not work. Work only buttons.
*Windows XP pro SP2
*3DS max 9 32bit SP2
*4GB memory
thanx you for your answer.
Problem with SpaceNavig in 3DS MAX9 after EXPORT/IMPORT Obj.
Hi Ivous
Could you specify what kind of files do you import and export?
Please describe a short scenario in order to reproduce. Could you send an example file?
agoenczi
Hi agoenczi,
I captured a video of my 3DS MAX. You can see it on this pages:
(it is XviD MPEG-4 Codec, 1.5MB)
http://www.brezina.cz/3dconnexion/
short description of videocapture:
1. I start the 3DS MAX and my SpaceNavigator work normaly
2. open the box with mouse and select IMPORT (or EXPORT)
3. the dialog box is appear and I click on STORNO button
4. SpacePilot doesnt work but buttons work normally
I try install on anothers computers, its same mistake
Thank You for your answer
Ivous
Ivous
Hi Ivous
The first step is always trying to reproduce... I will do it and I will let know about my findings.
agoenczi
Hi Ivous
I could reproduce the issue. Could you check what version of 3DxStudio do you have? You can check it by opening the file: "Start -> All Programs -> 3Dconnexion -> 3Dconnexion Plug-In for 3ds Max 9 -> Readme" and looking at the record following "CHANGES FROM PREVIOUS VERSIONS", there is a record with the current version. For your information I reproduced the issue with 3DStudio Max 9 (32 bit) and the Plug-In 3DxStudio v4.4.7.
agoenczi
Hi Ivous
Uncheck the checkbox "Suspend Motion" in the Plug-In and the navigation will work again. This is a known issue registered under # 4386 (for your reference).
agoenczi
Hi Ivous
At the moment the simplest solution is to switch-on the 3Dx Control Panel and uncheck the "Suspend Motion" checkbox.
4386 is an internal tracking number of this issue used by 3Dconnexion, the exactly same notation you will find under "CHANGES FROM PREVIOUS VERSIONS", for instance:
Fix [4445] Perspective View flickering
agoenczi
