3Dsmax mcloth not working
Hi, so mu mcloth function in 3Dsmax wasn't working any more.
Tried a gazillion things with no efect. But after un-installing de 3Dconnexion drivers, mcloth worked again.
any ideas?
any ideas?
Re: 3Dsmax mcloth not working
Hi dexyd,
can you provide a detailed step-by-step description how to use the mcloth function in 3dsmax? That would help us to reproduce the issue.
I have exactly the same problem using 3DS Max 2017 (also wasn't working on 2015). Just uninstalled 3DConnexion drivers and it works.
In answer to your previous, open max, create a sphere above the ground plane, open the Mass FX toolbar, then, with the sphere selected, press the add cloth modifier (T-SHIRT). Then hit PLAY in the MASS FX toolbar. the sphere should drop and crumple into a mess. Before uninstalling, the sphere would not do anything!
Need a fix for this as I use my Connexion mouse for Solidworks!
Hi geoffneck,
thanks for your help to reproduce the issue. I was able to reproduce the situation. I have created a bug for our development to fix this. Our internal bug number is #7335. I will post here is I have news about this. In the meantime please bear with us for a while. Thanks.
Thanks. Good to know this is being looked at.
Can we have an update for this technical issue please?
Hi all,
our development has created a fix for this issue. The new plugin isn't published yet, but if you are interested to test the beta version of the plugin let me know. I will then contact you with more details.
I'm interested to test the beta version.
I sent you an email.Expohouse wrote:I'm interested to test the beta version.
Having the same issue.
Could you forward the beta to me as well?
I appreciate it
I appreciate it
jsbenson wrote:Having the same issue.
I appreciate it
I'm kind of stuck until I can get the beta driver. Can you send it via email or provide a link, please?
UtaSH wrote:Email sent.
Awesome!
Thank you
Works perfectly!
I'll let you know if I run into any bugs.
same issue
Max 2017 SP3
3DxWare64_v10-4-10_r2558
coul you send me the beta fix ?
Thx
ZaK
same issue
Max 2017 SP3
Thx
ZaK
