and thanks for the great product, allthought it's not working as I hope
I have two different problems:
1) I use the SN with PhotoshopCS3. It's very nice and useful, but there is one major issue... The PS.CS3 crash every time, in 1 minute or in 1 hour but its sure as sunrise, it will crash. What should I do?
The problem has something to do with the CTRL. When the PS is shutting down and after it seems like some magic finger is pressing the CTRL. After crash I cant do nothing before i've pressed the CTRL.
First I thought it might have something to do with the buttons, but I disabled both but still...
This strange CTRL-problem doesnt exist with any other apps, only with PS.CS3 + SN.
My setup: PC (IBM z60M 2.00ghz w/1.5gb ram), Photoshop CS3 English (v10.0), finnish keyboard, some customed shortcuts.
SN info: release 3.3.6, driver 6.3.3, firmware 3.18, connected straight to the PC's USB, not hub.
Photoshop used to work like a dream til I connected SN
I hope there is some trick how to fix this, I can't stop using the PS and I don't want to stop using the SN, it's allmost like a part of left hand
2) I tried to customize some functions. There was some great tips&hints on the forum, but still...
If I do some changes (like changing the button actions, the buttons work as I want) but where are the changes saved? I thought there should be some scg-file like myname.scg, user00.scg etc, as the tips on the forum says. But believe me, I can't find any of these! If I manually change some lines in the photoshopcs3.scg the 3dxware and SN works I as want, but if I do some customizing to control panel GUI, changes are saved but I really don't know where! I've looked into 3Dconnection-, c:-, %APPDATA%-etc folders, but there are none .scg-files (except the original ones).
Now the path to the default files is this:
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\profiles\defaultAnd why I'm interested about this... I'd like to do some custom functions AND make the spin to do what I want (zoom or brush size etc). Now I can do the custom functions, but I can't do both because I'm not sure about the right syntax.
Is there any guide for tinkering the scg-files? I'd like to try different functions with the buttons (default functions, custom functions, etc) and most definitely some customizing to the SN (spin zoom, spin to change brush size/brush hardness etc...)
I hope some one could help me with this, I love the SN but the PS restarting is pi$$ing me off
Thanks in advance!
