Hello. I use the space pilot for animation on XSI.
It seems that when the autokey is activated, if I move the User camera with the joystick, XSI remembers these moves as if I moved a camera and put a key on it. But the user cam has no key and the animation cannot be removed. Moreover I cant use anymore the standard view moving shortcut.
The only way to animate with the space pilot I found until now is working without the autokey.
Second trouble. I can't navigate in the Animation editor with the joystick. It would be nice if it was possible. Does anybody knoes how to do?
Third. Will it be possible in the future to assign shortcuts to the space pilot keys?
Like key 1 : SHIFT+A
Key 2 : SHIHT + B
etc
Thanks a lot.
Matthieu
[XSI] Space pilot some troubles
Hi Makomako,
Could you describe a scenario in order to could reproduce your problem with the camera?
Second trouble: The SpacePilot is a 3D navigation device and the Animation Editor is a 2D view. And the 2D views couldn't be handled with 3D functions.
Third. Open the button mapping editor and under Command categories you will have a category "Customization". You could define own functions (with own keystrokes in XSI) which you could map on the keys of the SpacePilot.
agoenczi
Hi and thanks for your answer.
About the weird camera thing
When I open a new scene. under the User camera, if the autokey is on, the moves I do with the space pilot are saved like a camera animation (pan, zoom rotate etc)
and I don't know where to delete these keys.
Moreover, the keyboard + mouse navigation ( s+mouse) doesn't work anymore.
For the second thing, it's sad but I understand. It would have been awesome to have the same moving control as Photoshop
And for the third, I'll try.
Thanks a lot
Thanks a lot
XSI
Hi Makomako
I tried to reproduce in the following way using XSI 6.0 and a SpacePilot with 3DxSoftware v3.3.2 (currently available for download):
1. Opened a new scene
2. Set the "Auto" option for keys
3. Created a sphere and changed some parameters
4. Navigated
Under the menupoint "edit" I had only operations referring to the parameter changes about the created sphere.
Did I miss something?
4. Navigated
agoenczi
