Windows 10 GDI Objects
LAYKE2L
Post by LAYKE2L »
Is there a reason why the GDI objects of the 3DxLCD10SPPRO.exe is at 8,000 when in Windows 7 it's only around 1000. With it that high it almost is too much to run Solidworks without the resource monitor screaming that the system high on resources & may fail if you continue. When Im running SW with Windows 7 I can have multiple programs open and Solidworks won't bring up the system resource message at all but on Windows 10 I'm lucky if I can run 2 programs before the resource monitor screams. If I close out the 3DxLCD10SPPRO program using Task manager, I no longer get warned.
Re: Windows 10 GDI Objects
Hi LAYKE2L,
which driver version do you have installed? The current version is 3DxWare 10.4.10. In case you have an older version please install the latest one.
LAYKE2L
Post by LAYKE2L »
I am using 10.4.10 on both systems.
