Rhino lag when switching to application with 3dxware 10.4.3
spacescapes
Re: Rhino lag when switching to application with 3dxware 10.
Post by spacescapes »
Hi Jwick.
I didn't see a "logging" icon in the systray. Not even sure what that is or how I would know it's on. However, I wanted to rephrase my description of the application-switching behavior since using the GrabHard code you supplied. Thank you again by the way. Opening a 2'nd instance of Rhino forces the 3DXEnterprise to lock to the newly started instance. Whichever instance that is started last is what the 3DX now controls. It's predictable so I can work with it. Still looking forward to a driver fix, but love the hardware.
Cheers,
Brian Jackson
Wengert
Post by Wengert »
Thanks Jwick for the solution. That got it working for me!
TDRAKE
Post by TDRAKE »
Any update on this issue?
The fix should be in the recently released driver. Let us know.
richard.aubin
Post by richard.aubin »
Problem is still there.
richard.aubin
My task manager shows that 3DxProfileServer.exe takes over when switching back to Rhino during the UI locking effect.
What sort of delay are you seeing? I'm seeing 1 second. Logging turned off.
richard.aubin
Almost 3 seconds with logging turned off.
TDRAKE
Post by TDRAKE »
There is still a lag but it's significantly less than before. I was seeing up to a 5 sec. delay after switching windows, now its 1 second or less. This is much more manageable. Thank you for the update!
heliosol
Post by heliosol »
I can also confirm this issue still exist, though somewhat diminished in the latest version (10.5.2).
The good news it's very easy to reproduce.
1. Clear out your current Rhino settings (i.e. delete Rhino.xml from C:\Users\[Username]\AppData\Roaming\3Dconnexion\3DxWare\Cfg)
2. Start Rhino
3. Open 3DConnexion app and make sure it's detecting Rhino
3a. Navigate using SpaceMouse Pro and confirm no lag when switching to/from other apps
4. Click Advanced settings
5. Reverse all axes
6. Close Advanced settings
7. Switch back to Rhino
7a. Navigate using SpaceMouse Pro and notice the lag when switching from other apps
heliosol
Post by heliosol »
A few more points:
1. When 3dware first creates the CFG file for Rhino, there is a section in it called Device, with the following content:
<Device>
<Name>SpaceMouse Pro</Name>
<VendorID>46d</VendorID>
<ProductID>c62b</ProductID>
</Device>
2. When I change any of the axes to be reversed, this adds a new Device section underneath, rather than in the same one, i.e.:
<Device>
</Device>
<Device>
<VendorID>0</VendorID>
<ProductID>0</ProductID>
<Axis>
</Device>
3. Combining the two under either Standard 3D Mouse Device or under SpaceMouse Pro does not change the lag, unfortunately.
richard.aubin
heliosol wrote:I can also confirm this issue still exist, though somewhat diminished in the latest version (10.5.2).
2. Start Rhino
5. Reverse all axes
I can reproduce the same.
richard.aubin
Re: Rhino lag when switching to application with 3dxware 10.4.3
Bump.
Why is this taking so long?
MartMl
Post by MartMl »
Im having same problem with Solid Edge ST10.
CupaJoe
Post by CupaJoe »
oh.stv wrote: ↑Tue Nov 01, 2016 5:21 am Hi,
i have the exact same issue. For me, in this state, my mouse is NOT useable at all.
@postalgbv
Can u pls explain where to add "<Grab>Hard</Grab>" exactly.
I already found the Rhino.xml file. But there is no "</CfgProperties>" in it.
Thx
@ 3D Connections please fix this issue it negates any purpose of ur product, which is to increase productivity.
When @postalgbv stated to put it in the xml files they meant the 3Dconnexion Rhino xml file here -> C:\Users\<UserName>\AppData\Roaming\3Dconnexion\3DxWare\Cfg
This fix works while Rhino is open but you still may see lag when opening it up. As a tip, you're looking for </CfgProperties> on line 15 in the file. Hopefully they come out with a full fix soon but it works for now. KEEP IN MIND this does lock your space mouse to Rhino while it's open. Hope this helped and good luck!
