Hi, have a problem
My FreeCAD is unable to find the space mouse. The menu tab says "No Spaceball Present". I have tried reinstalling freecad but it won't help. Anyone had the same problem?
Unable to find the space mouse
Re: Unable to find the space mouse
Hi Kov_T,
we (3Dconnexion) do not have official information that FreeCAD supports our 3D mouse devices. See our list of supported applications.
However I did some research in the web and found it seems that FreeCAD has implemented the support for the SpaceNavigator using a third party driver which we do not support from our side. You will have to address this with the FreeCAD community.
My computer cannot find my Spacemouse either.
When I run in terminal, it hangs until I unplug the Spacemouse. The same happens with and on system start-up and shut-down.
I'm running Ubuntu 16.4.3 LTS with spacenavd. I tried also 3DxWare with no luck (hanged as well) but this might also be due to spacenavd being installed. Yesterday I found some instructions that I should have done something like this: (eg. here viewtopic.php?f=22&t=1388) but terminal tells me that the mount point does not exist.
Yet dmesg seems to find it:
But I don't know how to advance from here.
I've tried to use my Spacemouse on an older (about 7 yrs) Mac Pro but the led only flashes on start up and the device doesn't work. I managed to get it working (still without the led
) on Win XP that is bootcamped on the Mac but I wouldn't want to start using it because my Linux system is way newer.
I sent a support request on this matter yesterday and I apologize that I only now post here and have more information.
When I run
lsusbCode: Select all
strace lsusbI'm running Ubuntu 16.4.3 LTS with spacenavd. I tried also 3DxWare with no luck (hanged as well) but this might also be due to spacenavd being installed. Yesterday I found some instructions that I should have done something like this:
mount -t usbfs none /proc/bus/usb Yet dmesg seems to find it:
[ 2193.973887] usb 3-13.3: new low-speed USB device number 29 using xhci_hcd
[ 2194.062861] usb 3-13.3: New USB device found, idVendor=046d, idProduct=c62b
[ 2194.062867] usb 3-13.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2194.062870] usb 3-13.3: Product: SpaceMouse Pro
[ 2194.062873] usb 3-13.3: Manufacturer: 3Dconnexion
[ 2194.063116] usb 3-13.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2194.063124] usb 3-13.3: ep 0x2 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 2194.089863] input: 3Dconnexion SpaceMouse Pro as /devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13.3/3-13.3:1.0/0003:046D:C62B.0005/input/input20
[ 2194.141118] hid-generic 0003:046D:C62B.0005: input,hidraw4: USB HID v1.11 Multi-Axis Controller [3Dconnexion SpaceMouse Pro] on usb-0000:00:14.0-13.3/input0
[ 2206.514764] usb 3-13.3: USB disconnect, device number 29I've tried to use my Spacemouse on an older (about 7 yrs) Mac Pro but the led only flashes on start up and the device doesn't work. I managed to get it working (still without the led
As I've tried to solve this problem I found out that the mounting-of-the-usb-devices -instruction has been deprecated since Ubuntu 13.04. The forum post does still point out that there might be other places where the same information might be found on a newer system but I'm not sure how to implement that.
https://askubuntu.com/questions/326597/ ... -in-ubuntu
Hello Animotor,
ubuntu is not a supported operating system. See here.
Additionally we do not support the 3rd party driver. You need to contact the provider of the driver for support with this.
The problem proved out to be hardware related and I've now received a new SpaceMouse Pro. Yay!
Before the issue was solved, the support person asked me to test the product on a supported system which was in my case a newest Windows version. This time the SpaceMous seemed to work first but then it started to jump on and off. The on-stages lasted always about 9 seconds but the off-stages grew 2-4 seconds longer on each round. After I reported this result to the support person, he instructed me to do a hardreset on the device but this didn't help. I will still post the resetting instructions here if it helps some one else. Although, I won't advice anyone to try this without consulting the support first.
Then I was asked to provide proof of purchasing the product (to check the validity of warranty) and after that there were a couple of other steps before a new device was delivered on my door.Unplug the device from the USB port, then press and hold 2 buttons (it does not matter which buttons) and plug the device back into the USB port while still pressing 2 buttons.
Keep the buttons pressed for at least 10 seconds.
